4 members (ndkid275, Wally / Montana, Hanks custodian, dt235sd), 88 guests, and 1 robot.
Topics128,131
Posts1,056,723
Members48,454
First post to Stovebolt and new to rebuilding ole' trucks. I just purchased a 1949 axle with a 1957 pumpkin w/ 3.90 gears. Any issue with this setup for my 1946 frame? I plan to stick to the straight axle and put in a small block V8. Any advice would be appreciated with regards to this hybrid axle.
back yard wrench turner
Welcome to the Stovebolt.
I put a '51 front axle and a '58 rear with a 3.90 gear in my '38. I changed my motor to a '55 GMC 270.
Your choice should be fine.
I see you are in Kansas, keep the reunion in mind for the 1st weekend after Labor Day.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
Moderator
Moderator
2 Offline
Welcome to the Bolt HC.
You will find a wealth of help here.
Just ask away and post a few more times, then you will have full access to the garage.
Wayne, is that a hint that you may be attending the Reunion this Sept?
I hope so!
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
