1 members (Alex52), 136 guests, and 5 robots.
Topics128,186
Posts1,057,211
Members48,465
My 1951 Chevy 4400 has all new brake lines and wheel cylinders.
Question: Is there an off-the-shelf master cylinder/booster combination available that would allow me to go to dual system braking with minimum re-configuring? All I've inquired about are said to be too small for the 4400.
Thanks for info.
DCB
David C. Baker
3B Offline
Hy David C. Baker, welcome, the stock master cylinder bore for your truck is 1 1/4", I wouldn't use a master cylinder with a bore smaller than that. A lot of the systems available use master cylinders designed for disc/disc braking systems, so additional residual pressure valves would be required for a drum/drum braking system, hope that helps.
I did my 52 4400 with a G30 chevy truck master off Rockauto and used a universal vacuum Booster. Mounting was a snap, by using a universal mount bracket and fabricated (4 )9x 3/4" did. stand offs. The standoffs were for building in clearance for the e brake. Let me tell you, once the brakes were bleed, the truck stops better than new.
Hi Jim Carter has them I believe it was $87 for dual master cylinder
TENINE
