10 members (Hotrod Lincoln, Gdads51, Paul Mullen, Ponchogl, DavidBraley, Bill Hanlon, Otto Skorzeny, TUTS 59, Shaffer's1950, 1 invisible),
100
Mod | | | Forums66 Topics128,185 Posts1,057,200 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2002 Posts: 4 New Guy | | New Guy Joined: Apr 2002 Posts: 4 | My 1951 Chevy 4400 has all new brake lines and wheel cylinders. Question: Is there an off-the-shelf master cylinder/booster combination available that would allow me to go to dual system braking with minimum re-configuring? All I've inquired about are said to be too small for the 4400. Thanks for info.
DCB
David C. Baker
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy David C. Baker, welcome, the stock master cylinder bore for your truck is 1 1/4", I wouldn't use a master cylinder with a bore smaller than that. A lot of the systems available use master cylinders designed for disc/disc braking systems, so additional residual pressure valves would be required for a drum/drum braking system, hope that helps. | | | | | Joined: Aug 2016 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2016 Posts: 34 | I did my 52 4400 with a G30 chevy truck master off Rockauto and used a universal vacuum Booster. Mounting was a snap, by using a universal mount bracket and fabricated (4 )9x 3/4" did. stand offs. The standoffs were for building in clearance for the e brake. Let me tell you, once the brakes were bleed, the truck stops better than new.
| | | | | Joined: Jan 2018 Posts: 10 'Bolter | | 'Bolter Joined: Jan 2018 Posts: 10 | Hi Jim Carter has them I believe it was $87 for dual master cylinder
TENINE
