| | | Forums66 Topics128,119 Posts1,056,648 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | I'm getting ready to change out my 6 lug front drums to a 5 lug disc and was wondering if anyone had recommendations for conversion kits? The prices seem to be all over the place and I don't see a significant difference in what you get. Currently I have been looking at kits without a master cylinder just so I can compare apples to apples.
Appreciate any insight into this.
Thank you
1950 Chevrolet 1/2-Ton 3100
| | | | | Joined: Nov 2012 Posts: 138 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 138 | I guess you are changing to five lug because of wheel availability? | | | | | Joined: Sep 2017 Posts: 147 'Bolter | | 'Bolter Joined: Sep 2017 Posts: 147 | That and because I already bought a new rear end that is 5 .
| | | | | Joined: Oct 2016 Posts: 916 'Bolter | | 'Bolter Joined: Oct 2016 Posts: 916 | I think I used the CCP kit without a master cylinder. Whatever you decide to go with, be sure to check the steering stops on both sides with the steering wheel turned to the max in each direction- my caliper brackets were hitting my steering stops, and after I clearance them, the first thing that hit a stop was my brake hose fitting at the caliper as it contacted the king pin boss.
I got my under the floor power master cylinder from Performance On Line (POL) and everything works very well with my stock brake and clutch pedals- it bolted right in. I am considering going to a remote reservoir, however, the idea of just clamping on a cover with two fittings to that "Corvette style" master cylinder looks kinda hinky and I can't really see it sealing very well, but perhaps I am wrong.
~ Dave 1950 Chevrolet 3600 3/4-ton with 261 engine & T5 Transmission | | | | | Joined: Jan 2017 Posts: 103 Shop Shark | | Shop Shark Joined: Jan 2017 Posts: 103 | I think I used the CCP kit without a master cylinder. Whatever you decide to go with, be sure to check the steering stops on both sides with the steering wheel turned to the max in each direction- my caliper brackets were hitting my steering stops, and after I clearance them, the first thing that hit a stop was my brake hose fitting at the caliper as it contacted the king pin boss.
I got my under the floor power master cylinder from Performance On Line (POL) and everything works very well with my stock brake and clutch pedals- it bolted right in. I am considering going to a remote reservoir, however, the idea of just clamping on a cover with two fittings to that "Corvette style" master cylinder looks kinda hinky and I can't really see it sealing very well, but perhaps I am wrong. Any reason why that m/c booster kit wouldn't work in a 3/4 ton? Are you running a stock clutch setup?
1949 3600
Don't sweat the petty things, and don't pet the sweaty things. Never play leap-frog with a Unicorn. 2 Wrongs don't make a right, but 3 lefts do. Of all the Henges, Stone is my favorite. If at first you don't succeed, skydiving is not for you. Here's a word I just made up.....Plagiarism.
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | I just finished the CCP conversion kit with 6 bolt roller bearing hubs on a 50’ 1/2t. The instructions mention the power master cylinder will not work with the stock manual clutch setup. I found no problem with the clutch or brake pedal. I am wondering if they meant to say three manual trans linkage ? I did install a 90* speedometer cable adapter to avoid a sharp bend in the cable. My truck has a 4 speed top shifter so shift linkage was not a concern.
I drilled another hole the exact same size as the stock hole to access the master cylinder fluid fill. Ordered another stock size rubber plug.
