2 members (Nick in Manitou, walterhvogel), 73 guests, and 2 robots.
Topics128,035
Posts1,055,559
#1253146 01/30/2018 12:53 AM
Does any engine components crossover on inline 6’s between GMC and Chevy?
Relating to 235/261 ability to swap with 248/270/302...timing cover, thrust plate and spacer, bell housing, flywheel inspection covers, clutch assembly, stomp starter linkage, fuel pump, distributor and coil. I think the starters and generators swap, too, starting with 1955.2 Chevy's and 1956 GMC's once both were 12 volts negative ground.
Matt
Add 228 to that GMC list.
Bob Giles #1253180 01/30/2018 12:35 PM
236, 256
