9 members (Bill Hanlon, Vice-Grip, klhansen, Otto Skorzeny, HandyAndy, KEVINSKI, 37 GC, Gazz, Hugh63c10),
114
0
Mod | | | Forums66 Topics128,114 Posts1,056,610 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2010 Posts: 20 New Guy | | New Guy Joined: Jun 2010 Posts: 20 | Hello! Searched around and still not quite clear. Will the cab from a 53 bolt on a 54 frame? I know the bed area of the frame is different, but can you bolt the 53 bed on the 54 frame? Thanks!
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Yes, the 53 cab will bolt to the 54 frame.
My guess is that 53 bed can be bolted to the 54 frame, but I do not know if the 53 bed mounting blocks need to be used, and if the 53 rear fenders are closer to tires with/without the blocks.
Maybe someone who has done this will confirm/clarify/correct? | | | | | Joined: Jun 2010 Posts: 20 New Guy | | New Guy Joined: Jun 2010 Posts: 20 | Thanks! I'm halfway there! | | | | | Joined: Aug 2003 Posts: 106 Shop Shark | | Shop Shark Joined: Aug 2003 Posts: 106 | You would need to use the 53 bed blocks because the rear crossmember has a different height metal mounting area. You'll also need to use the 53 running board aprons as they are taller and match up to the 53 bed. The fenders will transfer over with no modifications.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert 55.1 GMC 450 COE 51ish GMC Suburban | | |
