5 members (Wayne67vert, 52Carl, Otto Skorzeny, Steelonsteel, klhansen), 101 guests, and 1 robot.
Topics128,113
Posts1,056,613
Members48,450
#1252881 01/28/2018 1:03 PM
Hello!
Searched around and still not quite clear. Will the cab from a 53 bolt on a 54 frame? I know the bed area of the frame is different, but can you bolt the 53 bed on the 54 frame?
Thanks!
Yes, the 53 cab will bolt to the 54 frame.
My guess is that 53 bed can be bolted to the 54 frame, but I do not know if the 53 bed mounting blocks need to be used, and if the 53 rear fenders are closer to tires with/without the blocks.
Maybe someone who has done this will confirm/clarify/correct?
Thanks! I'm halfway there!
Y
Y Offline
You would need to use the 53 bed blocks because the rear crossmember has a different height metal mounting area. You'll also need to use the 53 running board aprons as they are taller and match up to the 53 bed. The fenders will transfer over with no modifications.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
