5 members (55shaker, 1955 1 Series, sron48, Doug Boudreaux, 1 invisible), 77 guests, and 3 robots.
Topics128,200
Posts1,057,405
Members48,471
My fronts are the dreaded widow makers I’ve found through research, they are also badly rested. What is the safest way to let the air out
Just take the core out of the valve stem. It will deflate safely. If the thing didn't hand grenade when it was aired up originally, the pieces of the rim locked together properly. Of course, it you've got a flair for the dramatic, just prop it up at the local rifle range and deflate it from 100 yards away with a .30-06! The tow company operator who trained me to recover wrecked 18 wheelers had a good method of deflating tires on crash-damaged wheels- - - - -he used a 1911 .45 automatic with full metal jacket ammo!
Sir Searchalot
Sir Searchalot
Safest way: Throw it over a cliff and drive away. Who needs split rims in their life? I got enough trouble.
Big Bolt Forum Moderator
as Jerry said, it should be fine to deflate by just pulling the core out of the valve stem.
Mike
Now here's a bit of oddball trivia- - - -I believe it's been against DOT rules to service RH5's for quite a while, hasn't it? A few days ago I saw a brand new lever tool that's designed to work ONLY with widowmakers- - - -on sale at Harbor Freight! Somebody didn't get the memo!
I kind of like the high power option and if I had the truck at the farm instead of here at the house I might give it a go. ;-)
Stuff I’m gonna work on, I swear
1963 C30 flatbed
1961 Apache 30 (parts, no title)
1960 GMC Big Bolt
Don't tweet, face, Google, or link. Just hanging in as long as I can...
I've had tire repairs/replacements done on RH5 wheels as late as Spring, 2018. I don't know if DOT regulates RH5's or not, but I have had tires repaired/replaced at three different tire shops in the last couple of years. Replacements for RH5's are pretty limited here, but I still have a couple on my '72 C50. I have had one shop refuse, but the other three shops didn't care.
Just last night I was perusing through an old International Harvester truck manual and came across this:
Lots more pictures
