1 members (Otto Skorzeny),
146
Mod | | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 120 Retired Construction Worker | | Retired Construction Worker Joined: Jan 2017 Posts: 120 | a 12volt system ? I figure not ,,and if so what is the part that will cut the voltage down ,a resister of some type?
Directions are just another man's Opinion
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | a 12volt system ? I figure not ,,and if so what is the part that will cut the voltage down ,a resister of some type? What clock, & What year truck, & What voltage battery do you have???? | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | He’s trying to sneak one in on us Tim.🤷ðŸ¼â€â™‚ï¸
| | | | | Joined: Jan 2017 Posts: 120 Retired Construction Worker | | Retired Construction Worker Joined: Jan 2017 Posts: 120 | You really got to know all this to answer? just kidding ya .. I hit the post button to quick guys,, it is my 1939 Chevy changed over to 12 volt ,,but the original clock was wired with 6 volts ..
My excuse is ,,the browies cane out of the oven the daughter was baking and I lost all mental ability to finish the post corretly ..
I have a guy across the street who is itching to get into the works of the old clock and get it going again..even after I told him that I never seen a clock run and keep time worth a darn ever in them old cars I have owned.
| | | | | Joined: Feb 2004 Posts: 29,817 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,817 | Most of the car clocks back in the dark ages were spring-wound- - - -at least the ones that didn't contain sand! It was wound by a magnetic coil and a set of points- - - -when the coil energized, it wound the clock spring every time the points made contact. To wind the clock initially if it was allowed to run down, we would repeatedly touch a battery cable terminal to the battery post which energized the solenoid several times and tensioned the spring. You'll need to use a resistor with enough value to avoid overloading the small magnetic coil- - -that might take a little experimentation to get the value right. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | So, what clock, from what year truck/car?
1954 was the first year for an accessory (wind-up) clock in a Chevrolet truck.
So, if you have an original wind-up car/truck clock, just use a 12v bulb, rather than a 6v bulb. | | | | | Joined: Jan 2017 Posts: 120 Retired Construction Worker | | Retired Construction Worker Joined: Jan 2017 Posts: 120 | good advice ,,when I get to the clock fixn I can use this info .. thx tim and jerry and martin ,,no ticket this time ,just a warning I guess..
