6 members (Hotrod Lincoln, GMCJammer51, jmoore, Forty9, 2 invisible), 117 guests, and 1 robot.
Topics128,196
Posts1,057,385
Members48,469
#1252239 01/24/2018 1:05 AM
I am looking to put a used seat in my 56 chevy 3100 rather than recover the old one. Question is does a bench seat from a later model pick up fit or do I have to look for bucket seats?
56trucknut #1252246 01/24/2018 1:55 AM
Get out your tape measure and head to your local Pick-a-Part. Bolt holes won’t line up but that’s why you own a drill.🛠
56trucknut #1252281 01/24/2018 2:24 PM
Y
Y Offline
Check out the bench seats from the early 90's. Simple but effective and you keep the classic bench seat look. In my 55.1 COE I'm using 2016 Honda Odyssey minivan 2nd row bucket seats. They are very slightly wide for the AD trucks but fit the wider Task Force trucks better.
"I always win." Working mainly alone I do not let my trucks win a war. Maybe a battle here and there but never the war.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
56trucknut #1254312 02/09/2018 12:57 PM
V
VEW Offline
V Offline
I used somewhere around 2002 Silverado/Tahoe bucket seats in my 41 because they have build in seat/shoulder belts and fold down arm rests. But the 41 is by no means "original".
~ Victor
1957 3100 - moved on
VEW #1254725 02/12/2018 6:54 PM
1988 to 1998 full size GM Truck bench seat works. I got a Bench from a 1998 single cab . Seat back pivots down as well to get behind the seat. The seat base that was on the 1998 seat was just the right height. Drill 4 holes and bolt in.
Tom
1950 3100
455lark #1254810 02/13/2018 3:53 AM
Will that also apply for a 1950 4400
I,m told tha cabs are the same 🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
1952 3100 panel (newest one)
Queen Creek AZ
yellosub54 #1254812 02/13/2018 3:56 AM
Robert
What truck is that pic. 🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
56trucknut #1254813 02/13/2018 4:06 AM
Y
Y Offline
The truck is just off the seat vendors website. It's a VERY purple 1954 Chevy pickup.
Robert
55.1 GMC 450 COE
51ish GMC Suburban
yellosub54 #1254853 02/13/2018 3:50 PM
here are a couple pictures of that 98 Truck seat in my 50, I like that the seat back is almost the same height as the original and does not sit up higher then the rear glass,
Tom
1950 3100
yellosub54 #1254877 02/13/2018 5:55 PM
Which vendor I like those seats would like to see if they still available
Thanks🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
56trucknut #1254942 02/14/2018 5:08 AM
Y
Y Offline
Tophat,
If you're looking for the vendor for the seat in the purple truck he's out of Santa Barbara, CA. He goes to lots of big swap meets.
Tom's Bucket Seats
(805) 689-4184
[email protected]
Robert
55.1 GMC 450 COE
51ish GMC Suburban
yellosub54 #1255003 02/14/2018 7:46 PM
Thanks got a hold of him and talking about getting the seats 🎩
Tophat
1950 4400
1949 3100
1946 2 ton flatbed
1949 3800 panel
Queen Creek AZ
455lark #1262773 04/16/2018 10:10 PM
455lark, thanks for showing yours, i'm going to get one for myself. All i have is the original frame, no sliders, cushions or valance, so I think it will be cheaper in the long run to go with a late model seat. did you have any issues with it being a little wider?
Moderated by  ndkid275, Phak1
