Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Peggy M, baldeagle, NJC, Charles in CA, 1 invisible), 39 guests, and 3 robots.
Topics128,005
Posts1,055,254
Members48,418
#1251925 01/21/2018 5:56 PM
Y
Y Offline
I need help to ID the engine in a 53 3100. The number on the pad behind the dizzy is LASI 83985. I believe its a 235, but hope to find out what year it was manufactured? Thanks
Phil
Block date C31
Head # 4 848 850
Head casting # 3836 848 GM 30
No # between dizzy and down draft?
Yes it has two or double pulley set up
Yakimabowtie #1251928 01/21/2018 6:20 PM
It looks like LAS is the Engine Serial Number prefix for a 235 on a 2100-2400 1953 car that was equipped with a Powerglide transmission and power steering assembled in the Tonawanda, NY plant?
Post all the codes shown here and we can help give a more complete ID.
Yakimabowtie #1251968 01/21/2018 11:38 PM
Does it have a 2-pulley harmonic balancer?
Yakimabowtie #1251994 01/22/2018 2:42 AM
Just to be pedantic, Carl,
Two pulleys, or two-grooved pulley.
Yakimabowtie #1252087 01/23/2018 12:45 AM
Pedantic? You got bad feet, Tim? Dr Scholl's gel inserts is the ticket..
Yakimabowtie #1252100 01/23/2018 1:50 AM
A bad "hammer toe" on both feet, Carl (Dr. Scholl's is no good for them - 2x14 weeks off my feet is the answer)
But, they do call that balancer/damper/pulley it as you did:
http://www.bhjdynamics.com/index.php?main_page=product_info&cPath=1_2_35&products_id=39
Yakimabowtie #1252105 01/23/2018 2:10 AM
Just to get anal about it, that's technically a two-groove pulley. Hammer toe looks to be potentially painful. eek
tclederman #1252240 01/24/2018 1:14 AM
The military bases require a CAC (Common Access Card) to enter the gates. My anal retentive pedantic retired Marine/Navy friend always tries to correct me when I say, CAC card. I immediately redress him and insist that I actually said CA card (which sounds the same). Squid (he was in the Navy at the end of his career) then gave me the stink eye.
My grandpa had a hammer toe on the piggy which stayed home. He had Doc Evans just chop it off. Shortly after that, it quit hurting after it started feeling better...
Back to the topic, tomato/potato. We all know what it is.
Carl
Yakimabowtie #1252245 01/24/2018 1:44 AM
These posts will/should probably be deleted, Carl (small loss)
I asked two doctors if they would just cut the toes off (one at a time) - saving me 14-28 weeks of no walking (using a "knee walker" on ground level).
These doctors like to "conserve" - yeah, right dang
