5 members (jmoore, Paul_WNC, Gdads51, Napco Man, Shardean), 55 guests, and 7 robots.
Topics128,021
Posts1,055,357
Members48,420
#1252049 01/22/2018 5:21 PM
Began workig on the box and fenders of my ‘47 3100 AD. It’s amazing how well bondo hides crime! ;-) I never realized there are 2 rivets on the back fender brace until I removed the bondo. Lots of painstaking patch welding and hours of metal finishing to boring the fender into shape. Bought a bullseye dent remover and a shrink disk to help. Have to be careful when using each so you don’t stretch or shrink too much. The shrink disk also is quite dangerous so care is important.
The box sides are warped and oil canned due to welding repair patches to the bolt hole areas. The warping was covered with...you guessed it...BONDO! Again two tools have helped straighten things. I still may have to use a “skim” coat though to make it smooth again.....
My question is replacing the front panel. If s it simply a matter of unbolting 10 nuts and bolts? The PO welded a panel to the front panel to the front crossmember.......originally were the front panel and front crossmember attached?
You can never predict what you will face when you start a project!
Any advice would be appreciated.
The front panel bolts to the bedsides and the front cross sill bolts to the front panel. That was my first repair, patching the rusted out lower section of the front panel. I learned how to remove warping and oil canning on that panel. Got it pretty straight, but it will take a skim coat to make it look good. I've looked at shrinking disks but never tried one. I'm just using an O/A torch for shrinking. Not familiar with a bullseye dent remover. on edit: I do recall seeing those, but forgot the terminology.
Take a look at the photos of the process here:
Bed Front Panel Repair (Start here and scroll to the right)
Bummer that someone bonded over the riveted fender crown brace. I have a front fender that someone did a lead repair on that I removed and easily metal-worked it out to need next to nothing afterwards. Another had a "woodpecker repair" around the headlight opening, They just got underneath and pecked away at it. ohwell
Here's more of my restoration.
Patch Panel Forming
I may have you beat on resurrecting a crusty rear fender. wink Fortunately(?) no one had "fixed" those before.
