1 members (Otto Skorzeny),
89
Mod | | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I have an opportunity to buy a '58 that is in black primer only. The current owner doesn't know how long it has been like this or what's under the primer. It's 4 hours away so I haven't had a chance to look at it yet. Is there an easy way to tell if the truck has rusted under the primer? Will I have to strip it all down to clean it up. Thanks for any advice.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | You dont really HAVE to, but body&paint shops wont guarantee their paint job over someone elses "work". Depends what you want to do with the truck. If you want your paint job to last,id say strip it. | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I know lots of people that prefer to drive there vehicles just primed. You don't have to worry about scratching it. What is the difference if it has been painted a color? You still don't Know what is under it. Your best bet is, if it is something you want you are better of to go look and make your decision from there. If everything looks good rough up the surface, spray on a fresh coat of black primer and paint as you normally would | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Primer only jobs are almost never done by professionals and usually hide lots of bondo. Take a magnet with you and try to figure out how much metal is left underneath.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Aug 2006 Posts: 237 Shop Shark | | Shop Shark Joined: Aug 2006 Posts: 237 | Would you guys that are the experts of that year truck tell us what the rust trouble spots are? Like on a 60-66, I can name the most common spots to check for rust and bondo. Anyway, I found a 59 I like and was thinking about getting that for my boys.
Jesus is Lord! Only through the blood of Jesus are you washed clean of your sins. Come see us... Dad's Chevy Our VideoGod bless you! Michael..
| | | | | Joined: Oct 2006 Posts: 289 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 289 | Michael,
Here is where to look. Front Fender eyebrows, fender tips near doors, bottom of doors, door hinge pockets, steps, cab corners. Those are common. | | | | | Joined: May 2006 Posts: 29 New Guy | | New Guy Joined: May 2006 Posts: 29 | I have used a magnet to check for bondo repair. Just 2cents worth. | | |
