| | | Forums66 Topics128,134 Posts1,056,402 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I need help to ID the engine in a 53 3100. The number on the pad behind the dizzy is LASI 83985. I believe its a 235, but hope to find out what year it was manufactured? Thanks Phil Block date C31 Head # 4 848 850 Head casting # 3836 848 GM 30 No # between dizzy and down draft?
Yes it has two or double pulley set up
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Does it have a 2-pulley harmonic balancer?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Just to be pedantic, Carl,
Two pulleys, or two-grooved pulley. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | Pedantic? You got bad feet, Tim? Dr Scholl's gel inserts is the ticket..
| | | | | Joined: May 2015 Posts: 11,076 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,076 | Just to get anal about it, that's technically a two-groove pulley. Hammer toe looks to be potentially painful.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Mar 2010 Posts: 10,281 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,281 | The military bases require a CAC (Common Access Card) to enter the gates. My anal retentive pedantic retired Marine/Navy friend always tries to correct me when I say, CAC card. I immediately redress him and insist that I actually said CA card (which sounds the same). Squid (he was in the Navy at the end of his career) then gave me the stink eye. My grandpa had a hammer toe on the piggy which stayed home. He had Doc Evans just chop it off. Shortly after that, it quit hurting after it started feeling better... Back to the topic, tomato/potato. We all know what it is. Carl
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | These posts will/should probably be deleted, Carl (small loss) I asked two doctors if they would just cut the toes off (one at a time) - saving me 14-28 weeks of no walking (using a "knee walker" on ground level). These doctors like to "conserve" - yeah, right  | | |
