1 members (KEVINSKI),
160
Mod | | | Forums66 Topics128,108 Posts1,056,230 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2014 Posts: 94 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 94 | Anyone remember seeing a Post/Tip/Article about the (2) Timing Cover bolts that screw in from the back side of the cover that necessitates removing the Oil Pan to get to them when replacing the Timing Cover gasket?
I seem to remember it involved threading the two existing holes so the bolts could be installed from the front, so as to not have to remove the Oil Pan when changing the Timing Cover gasket.
I'm in the process of Overhauling and would like to do this mod while everything is open.
I suspect I saw either here or at "DTN" Deve's TechNet forum, but can't find it. Anyone do this or are familiar with the post? Thanks, Jim | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Oct 2014 Posts: 94 Shop Shark | | Shop Shark Joined: Oct 2014 Posts: 94 | "tc".....you 'da man thanks, Jim | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I performed this mod back in 2005 when I rebuilt the 235 in the '51. It was easy and proved to be quite a time saver when I had to replace the cheap chrome timing cover I tried to use. I highly recommend it.
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | Once an engine is built up[ properly with an original equipment timing cover and a good quality seal, it's highly unlikely the timing cover will need to be removed for quite some time. That bolt arrangement was a holdover from the time that main bearing clearance on the 216's and splash-oiler 235's could be adjusted with shims. It was a lot easier to pull the two bolts from the crankcase side than it was to fight with the front motor mount to get to the bolt heads from the front.
With timing gears (not a chain) that last 3 days past forever, and high quality synthetic rubber lip seals that don't dry out and leak, why would anyone want to pull the timing cover between major overhauls? Jerry
| | | | | Joined: Mar 2010 Posts: 10,280 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,280 | Jerry makes a good point. I believe the mod comes from everyone who has ever had the misfortune of inheriting an old engine with a leaky timing cover seal and have to go through a lot of difficult work to fix it, including removing the balancer, and dropping the oil pan, creating the possibility of causing another leak there. So after all of those headaches, we decide that we are not ever going through that again! This frustration muddies up our judgement, in terms of what Jerry has brought up. That is, you probably will never have to do it again until the engine is worn out, requiring us to pull it out of the truck and tear it completely down on an engine stand, making the original design no so much of a problem. Carl.
| | | | | Joined: Feb 2004 Posts: 29,803 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,803 | When we built up John's 261 late last year, we discussed the exact same scenario, and decided to reassemble it "as designed" without converting the timing cover to "front only" bolts. I really doubt if it will make much of a difference. Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I agree with the naysayers regarding the need/justification to do that modification.
However, if I have the engine apart (and/or the timing gear cover off), my lazy/simplistic attitude is "why not". That 15 minutes might save me time/effort/swearing and a lot of effort (before I die) or save someone else that effort (after I die)? | | | | | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I think Tim has it right. It may not be necessary, but if you already have the engine apart, you might as well. And, the price is right.
| | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I agree with everything Jerry said, but I never thought of it that way! I just focused on the nuisance aspect!
Another reason (also completely unnecessary) that I like to do the modification is that the timing covers differ for AD, TF and 60-62 trucks because of the engine mounts. The shape of the timing cover is exactly the same, the bottoms have different hole patterns because different style engine mounts were used. AD's have the square holes to accept a carriage bolt dropped from the top down, the TF's don't have any holes and the 60-62's have round holes. They can all be adapted to fit any model, but if a guy wants the correct timing cover to fit the engine mount for a particular year truck, or wants to remove the timing cover to adapt it to fit a particular year, this modification makes it an easier task because the pan doesn't have to be dropped.
Matt | | |
