6 members (TooMany2count, 78buckshot, Gdads51, KEVINSKI, dt235sd, 1 invisible), 161 guests, and 1 robot.
Topics128,081
Posts1,056,069
Members48,434
#1251632 01/19/2018 4:44 PM
Wondering why there is a rear seal listed for torque tube applications? Can anyone shed any light on this? Is it to control the amount of oil spilling over the seal to the front u-joint enclosure?
Trying to wrap my head around this.
Thanks in advance,
Steve
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
I've seen that in the manual Tim. The sm420 has a seal in the transmission around the main shaft in front of the input yoke and I dont know why or what purpose it holds.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
Sorry, sstock,
I have used a few open driveshaft SM420s in/on torque-tube trucks. I have "converted" open driveshaft SM420s to torque-tubes. I'd have to see a photo of what you are referring-to?
Maybe someone else will be helpful?
Look at the seal 5.555 in this illustration.
http://chevy.oldcarmanualproject.com/parts/1929_54/220.htm
part number 591448 http://chevy.oldcarmanualproject.com/parts/1929_54/275.htm
Thanks in advance
, Steve
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
This Rear bearing retainer uses the oil seal.
That rear bearing retainer was/is used on 3/4 ton and 1 ton open drive shaft trucks.
Here is a Picture of SM420 4 speed with a closed drive shaft (torque Tube) rear bearing retainer used on 1/2 ton trucks. No need for oil seal.
The link http://chevy.oldcarmanualproject.com/parts/1929_54/220.htm you provided is showing a open drive shaft rear bearing retainer.
Thanks Jorb for you shedding light on this, I suspected this but had to be sure.
1953 Chevrolet 3100
In the DITY Gallery
1964 GMC 1000
