| | | Forums66 Topics128,056 Posts1,055,789 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Dumb question for the day... I know pinging is mostly about timing, but if valves are not adjusted properly, can that cause pinging?
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | Nope- - - -"ping" is slang for detonation- - - -the noise caused by two flame fronts traveling opposite directions across the combustion chamber. The second flame front is caused by something called "pre-ignition"- - - -burning of the fuel begun by something other than the spark plug. The source of the preignition can be a glowing piece of carbon in the combustion chamber, too lean mixture which causes the fast-burning flame front to push a pressure wave ahead of it and cause the mixture to "diesel", or several other factors. Too-early ignition timing and/or too low octane gasoline for the compression ratio can also contribute to detonation. Once the second flame front begins, the noise created by the flame fronts slamming together is loud enough to be beard through the cylinder walls, coolant, and cylinder head structure.
Gasoline engine detonation is the most powerful destructive force (other than nuclear) known to science. It is much more destructive than an equivalent weight of Dynamite, TNT, C-4, etc. Jerry
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Thanks teach. A thorough answer as always.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | I think he heard something like "increasing your valve lash will delay intake valve closure, and increase cranking compression". It will, but not enough to ping unless: 1. 1/16" lash 2. engine is already borderline | | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | "Delay"??????? I'd like to see that demonstrated. It seems that it would shorten duration and make the valve close sooner- - - - -which could increase the compression stroke and compression pressure- - - -in theory. Jerry
| | | | | Joined: Feb 2000 Posts: 5,203 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,203 | Lash will effect the opening timing and closing timing of the valve. More lash equals shorter time valve is open, less lash, valve is open longer.
A valve itself can cause pinging, ONLY if it has a carbon build up enough to glow just as Jerry explained, usually around the edges. I could see how to much lash could possibly cause some pinging if the valve doesn't open enough to fully fill the cylinder, thus causing a lean condition, but, it would have to be pretty far off I suspect. | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | Ooppsss! Shorten is of course correct. | | | | | Joined: Jul 2008 Posts: 181 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 181 | I recall reading somewhere that a heat riser valve stuck in the closed position can cause excessive pinging under load. is this possible? | | | | | Joined: Feb 2004 Posts: 29,773 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,773 | Yes- - - -it raises the temperature of the intake mixture to the point the fuel/air mixture is easier to compression ignite before the spark plug fires. It's similar to how glow plugs in a Diesel engine preheat the air so the compression can raise the temperature enough to light off the fuel. Diesels need to raise the combustion chamber temp to around 1,000 degrees F. before the fuel will light off. Preheating the intake air in cold weather helps that happen, and it's also why starting fluid should never be used on a glow plug equipped engine. Ether and red hot glow plug filaments don't play well together! Jerry
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Valves that have been ground to a point where the edges are thin can cause pre-ignition. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
