| | | Forums66 Topics128,049 Posts1,055,679 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | I was going to replace the broken windows in my 1935 pickup and discovered the rail/channel that the window sits in is rusted out. When I got if off the glass and the old setting tape off I noticed the channel had split and could not be reused. I have two questions, the first being, what is this metal channel called. The second question is where can I get a replacement? It is an unusual piece because the top part of this piece has a channel that the glass is inserted into and the underside has a track with a groove that the window regulator arm ball runs in that is curved. Any ideas? Thanks in advance!
| | | | | Joined: Jun 2005 Posts: 1,001 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 1,001 | Rick Hopefully I will provide some help and at least give you a bump. I've never worked on a 35, but someone here has and hopefully will help you out. One the vehicles I have worked on, the channel that holds the glass is what you said, "window metal channel". It has a rubber sealing strip that goes on the bottom of your glass and sets into the metal channel. I'm gonna be no help on where to get one except to check with vendors for repros or used. Chevy of the 40's, The Filling Station, or others out there may help you out. Good luck!
~ Victor 1941 3/4-Ton Pickup (in process). Read about it in the DITY Gallery1955 Grumman Kurbside "Doughboy" 235/3 on tree w/ OD 1957 3100 - moved on 1959 C4500 Short Bus "Magic Bus" - moved on 1959 G3800 1 Ton Dually "Chief" - moved on 1958 C4400 Viking "Thor" ~ moved on to fellow Bolter | | | | | Joined: Feb 2006 Posts: 222 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 222 | Victor Thanks for confirming the name of the part. This week I am going to call around the parts places listed in Hemmings and see what I can come up with. Worse comes to worse, I will see about some used ones but I fear they would be just like mine. Thanks again for answering my call! | | |
