| | | Forums66 Topics128,196 Posts1,057,391 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well, here I am again, axing for someone to switch the lights on out there in that cold cold garage so they can take a peek at how one of their toys are made. This month I’m embarking on that tool of all tools…..the English Wheel! Been wanting one for decades and I’ve had the tubing for the frame, the wheel and anvils, the casters, and enough material I should be able to fabricate the adjuster….on the shelf all that time. So the rest of the winter will be devoted to my wheel. I’ve been working for a couple of days on trying to decide from the few hundred designs, which parts I’d like to incorporate in my wheel. I’m not wanting one of those master pieces that look like it belongs in the museum of modern art, nope, just a plan old fabricated ridged tube frame English wheel. I’ve pretty much much settled on something similar to the Metal Art wheels like the Covell series. The brick wall that I’ve run into is the lower lifter/adjuster/quick release mechanism. I’ve got tubing that will work, I can fab the eccentric, I’ve got some 1”-5 Acme thd. rod and nuts but I just can’t quite figure how it all goes together. I’ve not seen one of the Metal Art adjusters that was disassembled and can’t see how it’s kept from rotating. I assume the upper shaft that slides in the lower tube, which is welded to the frame, has a slot milled in it and a set screw or shoulder bolt is keeping it from turning. But that doesn’t seem good enough to keep the anvil on track. And, I assume that the kick adjuster shaft is threaded up thru a nut somewhere in the lower tube and pushes up on the quick release eccentric. What I would really like is for anyone who has one of the Metal Art wheels to lay the parts out and photo graph them when it’s apart. Some rough measurements would save me a lot of time also. I know there has to be one of you fabricator guys who has one of these or knows someone who has one. It would sure save me a lot of mistakes if you could show me how they are doing it with their adjusters. Thanks Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Oct 2005 Posts: 4,261 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,261 | You'd think square tubing for your telescoping part would be better for keeping things on track. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Yes, lots of the DIY guys do that Mark. But....the sacrifice is that is not as precise as a quill unless it has all machined surfaces, like in an arbor press. The large area required for the Poly sheet gibs that most of the guys are using, creates a lot of surface area. A large surface area means a lot of friction. Single point gib screws would only work if all the surfaces were precision machined. If you look at all of the wheels that are built for professional use, they all use a tube in tube lower adjuster. I'm getting things worked out but still have a few snags. I was really hoping with all the car guys that are here doing restoration and custom work that one of them would have a commercial wheel that they could give me some input on. DG
| | | | | Joined: May 2015 Posts: 11,186 Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums | | Housekeeping (Moderator) Making a Stovebolt Bed & Paint and Body Shop Forums Joined: May 2015 Posts: 11,186 | Denny Shoot a PM to MPandC. Robert either has an English Wheel or has seen enough of them to help you out.
Kevin 1951 Chevy 3100 work truckFollow this saga in Project JournalPhotos 1929 Ford pickup restored from the ground up. | 1929 Ford Special Coupe (First car) Busting rust since the mid-60's If you're smart enough to take it apart, you darn well better be smart enough to put it back together. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 |
| | | | | Joined: Apr 2005 Posts: 7,441 Bolter | | Bolter Joined: Apr 2005 Posts: 7,441 | That’s his Stovebolt handle. Metal worker.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Hello, Denny It is a member "name": MPandC from searching the User ListHappy New Year - good luck with your project. | | | | | Joined: Jul 2011 Posts: 785 'Bolter | | 'Bolter Joined: Jul 2011 Posts: 785 | Denny, if you check the first couple of sticky threads in this link they show frame fabrication as well as adjusters. For whatever reason, most don't use an Acme thread on the adjuster on fabricated wheeling machines, they will use fine threaded all thread. My cast wheel uses an Acme thread and does fine with it. http://www.allmetalshaping.com/forumdisplay.php?f=29If pictures don't show you may have to sign up for the site. | | |
