7 members (Shaffer's1950, 54farmtruck, Southerntruck, Lightholder's Dad, Pre '68 Dave, Donf, rfs56trk),
126
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,189 Posts1,057,337 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2017 Posts: 5 'Bolter | | 'Bolter Joined: Jan 2017 Posts: 5 | My 1951 GMC did not come to me with an engine. I found an old one, had it rebuilt and it's now ready to mount into the frame. So here is the questions... Is there a hardware specifications manual anywhere that I can determine what bolts are required to mount my rebuilt 228 to the front and two side mounts? I'm ready to go but don't know what size grade 8's to use. Your help would be greatly appreciated!
| | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | What ever fits in the holes..........memory ( which is not always reliable) thinks they are 3/8” on the rear frame mounts and captive 7/16” carriage bolts on the stock front frame mount. The front had lock type nuts as well again on memory.
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here's the parts manual/catalog, engine mounting is covered in first few pages of the engine section http://chevy.oldcarmanualproject.com/parts/1929_54/index.htmOops, that's the Chevy parts catalog, but should be same or similar enough for the GMC engine mounting.
