Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
3 members (GMCJammer51, Pre '68 Dave, 1 invisible), 566 guests, and 1 robot.
Topics126,777
Posts1,039,270
Members48,100
Most Online2,175
Jul 21st, 2025
Hey guys, new to the forum here. I just procured a 1970 Chevy c50. Previously a roll on tow truck. getting ready to dig into this project. It has good wheels on the rear end but I need new front wheels and tires. What should I be looking for? I have been reading through the forums here but haven’t found a definitive answer on where to go. Much appreciated for any help
Anybody on here from eastern pa?
3B Offline
Hy Steve70c50, welcome, we need some more information to properly answer your questions. Are you running tube type wheels/tires or tubeless? What is your wheel lug bolt circle dimension and number used for each wheel?
Welcome,
You’ll find some good resources and info starting with this thread.
https://www.stovebolt.com/ubbthread...els-and-tires-what-to-do.html#Post867617
1952 Chevrolet 3800 pickup
---All pictures---
Thanks after reading the thread I see they have a chart. Not sure how to decide if mine are useable or the deadly kind. 10 lug I believe 8.25-20
Big Bolt Forum Moderator
The easiest way to tell if you have the "deadly kind" is to look at the fronts, if you can see a split ring on the outside of the front wheel, they are not the Firestone RH5. Those, you would look at the rear outside dual, the split is there on the flat part of the wheel.
Mike
Crusing in the Passing Lane
1970 is probably tubeless, unless changed.
Ed
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.055s Queries: 14 (0.024s) Memory: 0.6208 MB (Peak: 0.6908 MB) Data Comp: Zlib Server Time: 2025-09-22 12:41:31 UTC
Valid HTML 5 and Valid CSS
