1 members (JW51), 115 guests, and 0 robots.
Topics128,081
Posts1,056,078
Members48,434
#1250156 01/09/2018 1:00 PM
Hello out there been quite a while since I have been on and not sure if I am in the right forum. I have changed my 54 panel to electric wiper motor and find that the original style wiper blades have become floppy. They have actually scratched the glass from bending. Everything is new arms and blades I don't think they were designed to stand the force that the electric motor is putting on them.. Can anybody recommend a replacement blade and arm if necessary, and were to git them?
Thanks Len
layback
I picked up replacement arms/blades from Southwest in FW when I swapped out the Trico for an electric. They work fine.
Are you certain the arms are fully seated? If they are not, the base will tilt slightly and they won't swipe correctly.
1955 Chevy (1st Series) 3600
The style of the wiper arm changed in 1954 (maybe because of changed to a 1-piece curved windshield?). I think the wiper blade length/style changed, too.
The problem is where the blade connects to the arm its very sloppy there. When its in operation the blade falls to its side going up then the other side going back .the leading edge is never straight on to the glass. I am considering adding some sort of wedge in the connection to stop the tilting ,clear silicone maybe. Perhaps its just a crappy aftermarket part.
Thanks Len
layback
You just solved your problem. "Perhaps its just a crappy aftermarket part."
Thank you another one solved.
Len
layback
