5 members (Danielbolt, Phak1, Bill Hanlon, 1955 1 Series, 1 invisible), 296 guests, and 4 robots.
Topics128,156
Posts1,057,021
Members48,460
I would like to raise the front end of my 52....seems to be down from stock hieght. Other than brand new springs...any sugestions?
I thought of looking into re-arching the springs.
Also, the rear spring shackels are a bit longer than the fronts...wonder if that would work?
Any thoughts appreciated, thanks.
k10 Offline
Call a couple of local sping suppliers. I think you'll find that new springs aren't as expensive as you may think. And the alternatives will still be a compromise. Just an opinion.
longer shackles, will work, just dont go more than about 2" longer, or you will start to notice the effects of your caster being tipped the wrong way (caster=you king pin, it wont want to drive strait)
BrianK
Sometimes, David beats Goliath. Nobody talks, however, about how many little guys Goliath already beat into the ground. . .
Also, afterwards don't slamb the driver door too much as the force may make your truck fall over...
54 3100 with 235
62 flatbed dump C60 with 261
Thanks for the tips...
I found a good spring shop close by, I'll talk with them. I'm after about an inch or two (WHO ISN'T!?)so I'll opt for their new springs and replace the bushings and all that.
