1 members (Materman),
115
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 40 | lurked for a while but I dont think I ever asked a question I am looking at a 65-66 chevy c60 it has the big 10 lug budd wheels, not the smaller 10 lug that uses 5 on the front is this factory? and will later 10 lug 19.5/22.5 wheels work on it thanks
I hit cars with hammers
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Anthony Myrick, if you have ten lug Budd wheels then yes 19.5", 22.5" and 24.5" ten lug Budd wheels will interchange. This was one of the factory available wheel mountings which were offered in the 60 series and larger trucks I believe, hope that helps. | | | | | Joined: Sep 2009 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 40 | [quote=3B]Hy Anthony Myrick, if you have ten lug Budd wheels then yes 19.5", 22.5" and 24.5" ten lug Budd wheels will interchange. This was one of the factory available wheel mountings which were offered in the 60 series and larger trucks I believe, hope that helps.[/quote] thanks had some folks trying to tell me this was not offered until the late 60s early 70s
| | | | | Joined: Apr 2003 Posts: 942 'Bolter | | 'Bolter Joined: Apr 2003 Posts: 942 | Here is a picture of a '64 C-60 with the 10 Lugs on the Front: http://www.chevyc60.com/images/1964_7.jpg
'60-'72 Chev/GMC Fan GMC 9500 Fan Detroit Diesel Fan
