1 members (keithfielder), 99 guests, and 4 robots.
Topics128,186
Posts1,057,318
Members48,469
I have this heater set up in my truck.Can any one tell me what sort it is(basic,deluxe or other).Also what controls all the flaps and valve(numbered).When I removed it it only had one choke type cable which went to the valve inside ,the other flaps had nothing on them.I also seem to be missing a switch for the fan.Finally what does the valve do?
[IMG]http://i1060.photobucket.com/a...110_154618%20stove_zpsgo3lhodt.jpg[/IMG]
[IMG]http://i1060.photobucket.com/a...ff/20180110_154702_zpsavnvmckg.jpg[/IMG]
[IMG]http://i1060.photobucket.com/a...ff/20180110_154815_zpsqyrlqjrg.jpg[/IMG]
Big Bolt Forum Moderator
that is the fresh air or deluxe heater. There are deluxe heater controls, (shown here) https://www.americanclassic.com/1955-59-Deluxe-Heater-Control-Assembly-w_-switch-Chevrolet/productinfo/68%2D478/
There are cables that go from the heater control to the heater itself. That valve controls the hot water flow through the heater core (as well as onto the floor in a lot of cases!)
Mike
What year truck?
What does the front of the heater look like?
There were different styles of GM "deluxe" heaters, with different controls.
I cannot view your photos for very long - photobucket full-screen pop-up ads takeover.
Tim, that looks just like the deluxe heater in a TF truck. (55.2-59)
Mike
Thanks, 69Cuda
I looked back at Stooby's older posts and a 1956 model was indicated in one of them.
Stooby - you might want to post year/make/model in each post - but it looks like 69Cuda has you covered.
Yes it's a 56 3100.
There is a stamp which says HARRISON F 55.Should there be a seal of some kind between the blower outlet and inlet to the heat exchanger. Few more pics
[IMG]http://i1060.photobucket.com/a...ff/20180110_202146_zpsb6drgwuv.jpg[/IMG]
[IMG]http://i1060.photobucket.com/a...ff/20180110_201858_zpstj0qtp0x.jpg[/IMG]
complete deal shown in the 57 accessory manual here - also some pics in my album here
Stooby, yes, there are seals that are missing. Basically, large wide rubber bands! One between blower housing and heater box, and a narrower one between the blower and kick panel.
https://www.americanclassic.com/1955-59-Deluxe-Heater-Bands/productinfo/68%2D701/
Nice album and details, Flxible!
Mike
Moderated by  ndkid275, Phak1
