5 members (Otto Skorzeny, jmoore, Hotrod Lincoln, Bill Hanlon, Ponchogl), 127 guests, and 0 robots.
Topics128,105
Posts1,056,209
Members48,436
#1250001 01/08/2018 3:01 AM
I want to build a rotisserie using engine stands for my truck bed, any ideas?
41 chev #1250005 01/08/2018 3:30 AM
I'm planning on doing that for the work on my cab.
One problem is that most engine stands have the axle angled up a bit, so you'd need to cut and reweld the top pivot tube so it's horizontal. The engine stands I got are 4-wheel type with the lower tube inserted in a socket below the upright. I plan on using a single tube inserted into each socket to hold the two stands together at a fixed distance so the whole assembly will sit on 4 wheels (rears on each stand). The rear wheels are fixed on both stands, so I plan on replacing them on one stand with casters from the front of one stand.
The bed, being rectangular is pretty easy to reposition with some blocking, so I'm wondering why you'd need a rotisserie for it, unless you're thinking on painting the entire bed while on the rotisserie.
on edit: I just remembered something else. For my rotisserie, I also need to raise the pivot point to clear the cab as it rotates. You might have to do something similar to be able to fully rotate a bed. It's going to take a touch over 2' of clearance, assuming you get the pivots at the geometric center of the bed. Attached is a drawing I worked up to see just how high the pivots needed to be to spin a cab around fully. It's going to take at least 3 feet.
klhansen #1250144 01/09/2018 5:56 AM
I want to paint under the bed has rust and grime
41 chev #1250146 01/09/2018 6:45 AM
I'd just flop it over on some 2x4's. Or better yet some short sawhorses so it's at a convenient work height.
41 chev #1250297 01/10/2018 3:57 AM
flop it over how?
41 chev #1250298 01/10/2018 4:02 AM
Originally Posted by 41 chev
flop it over how?
You and a helper. They're not that heavy.
41 chev #1250715 01/13/2018 3:22 AM
it's a long bed and it's pretty heavy
41 chev #1250735 01/13/2018 5:00 AM
You and THREE helpers? wink
klhansen #1250776 01/13/2018 3:28 PM
Kevin, I just finished a cab off resto, and if I were to do again, I would look further into the rotisserie. In fact, I think a good pivot point would be about the top of the engine recess in the cowl, to make it less top or bottom heavy.
1953 Chevrolet 3100
In the DITY Gallery
Video of the 261 running
1964 GMC 1000
sstock #1250809 01/13/2018 7:21 PM
Actually, my plan is not to rotate it about the front to back centerline, but crossways, mounting the cab using door hinge and strike attachments. I realize it will make getting to the interior a bit restricted, but I think I can deal with that. I figured the geometric center of the cab using the cab dimension figure from the FAM (Sheet 1.07). The height of that point is a bit below the top hinge, corresponding with your recommendation. My cab floor is where most of the action will be and there's not enough meat left there to support it from there, like a "standard" rotisserie would.
Moderated by  MNSmith
