Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (walter74, Bill Hanlon, 68ironhead, JW51, Greg_H, Peggy M), 63 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#124987 03/10/2007 4:35 PM
1 Offline
I was reading a post from a guy who said that he needed to remove all of the "bolt on" and riveted frame members when refinishing the frame.
Do you all agree? I was just planning on leaving the bolts and rivets in place, sanding them down as well as I can, hit it with a rust converter and then coat with rubberized topcoat.
What do you all think? Do you really need to remove all of the bolt on pieces?
I want my truck to turn out nice, so I am willing to do whatever it takes; I was just surprised when I read that.
Thanks for any advice!
Ross
#124988 03/10/2007 5:11 PM
If you want to remove the bolts thats ok but stay away from the rivets. They are not meant to be removed.
1949 Chevy 6400
1931 Chevy Firetruck
#124989 03/10/2007 5:15 PM
some folks just get a bit anal about their 'restoration' - no riveted frame member "needs" to be removed for refinishing, and it's a real bad idea .... I don't think you'll find any bolt on frame members, but any other bolted on parts could be removed if there looks to be any real corrosion between them and the frame
your plan is the common one, and does the job fine .... remember so far the frame has lasted well enough to just need a clean up, it's likely to see more years than you will grin
#124990 03/10/2007 6:04 PM
1 Offline
Bill and 31,32,33 -
Thanks for the tips. I thought it sounded kind of crazy to remove the rivets that took tons of pressure to install at the factory.
I am also glad to read Bill's comments (again, thanks) on the bolts. I had to grind off most of the nuts and bolts that held the bed sheet metal on.
I think I will stay on my original plan.
Ross
#124991 03/11/2007 8:22 PM
I can only think of ONE reason to remove any of the frame rivets-And that's only if you need to replace/repair a crossmember, say one that's bent or rusted too badly to repair. If you would have to do that, you can replace the rivets with grade 8 bolts, making sure to have no threads in the hole. It would have to be a tight fit in the hole to maintain the same strength as the original rivet.
Bill Burmeister
#124992 03/12/2007 3:17 PM
i had to replace the main crossmember on my 49 1/2. it was pretty rusty and wss better off to replace than repair.drillrd out the old beat it out witha bfh and bolted in with grade 8 was a pretty smooth operation.....dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
