8 members (Guitplayer, 78buckshot, Otto Skorzeny, cmayna, Cletus1950, Southerntruck, 1955 1 Series, Wayne67vert), 99 guests, and 1 robot.
Topics128,156
Posts1,056,871
Members48,456
#1249246 01/02/2018 10:00 PM
Being that I like to have froze my bottom off yesterday morning to drive the truck — its time to do the heater thing (south Louisiana won’t use much, but this week is a real bear).
IS there a tutorial anywhere I can read on hooking up a deluxe heater? I’m a bit befuddled on the wiring?
Power wire going to switch from fuse block, but them there are 3 spades from dash fan switch?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
High/low speed fan?🛠
looks like there is a run to the heater duct box. Maybe for a thermostat?
~ HB
1962 Chevrolet C10
1962 Suburban
Sir Searchalot
Sir Searchalot
The fan switch is wired to a "resistor assembly" mounted to the back side of duct. It's coils are inside probably for "cooling" by the airflow and no chance to burn you or something else. It has 3 contacts on the outside of duct. Fan switch has 4 contacts, one is hot feed. Factory Maintenance Manual Diagram shows how it's wired up or I can give a to-from list.
The "resistor assembly" is a typical speed control device remotely mounted away from switch.
Bartamos, I would love a to from list, if you don't mind.
Sir Searchalot
Sir Searchalot
Sent
I have to save this as I think a complete rebuild on my 63 is in the future
I have a 55 second gen!,, work in progress
1963 long bed step side driver
Just a guy who digs old trucks!
bart, nothing yet.
Sir Searchalot
Sir Searchalot
Hopefully you can wire this with the resistor assembly loose just to test the operation of motor before installing the resistor way back behind. I don’t know if you have the original harness and it’s connectors that plug into the switch or the resistor. I don’t know if your wires will follow the colors on the wiring diagram I have. The colors are not critical, just how it’s wired, but I will give the colors on the diagram.
Starting at bottom contact of fan switch:
1. A wire from the fuse panel from a 10A fuse goes to bottom contact on fan switch. This is the hot feed. (BRN)
2. A wire from next fan switch contact goes to an outside contact on the resistor. (YEL)
3. A wire from next fan switch contact goes to center contact on resistor. (BLU)
4. A wire from next fan switch contact goes to the other outside contact on resistor. (ORN), then a wire from this resistor contact goes to fan motor (ORN)
There is a lamp on the 4 lever heater control assembly, it’s wire is connected in with the other panel lamps. (GRY)
The fan switch up, is off, then low, med, hi. If it does not operate like that, reverse the outside wires on the resistor assy. The diagram I have does not show which outside contact is which.
To clarify:
The "outside" contacts are vertical and the center contact is horizontal on the resistor assy.
Please let me know if it works. No hurry.
Sir Searchalot
Sir Searchalot
Modelman has found a harness that hooks it all up for $25 with all the connectors. That is the way to go. He will post the info I hope.
Is this the harness you are needing ?
1960-1963 deluxe heater harness
Tim
1951 3100 Chevrolet
Sir Searchalot
Sir Searchalot
Yes that is the one he already found. I just did not want to steal his thunder.
