Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (klhansen, carbking, 1 invisible), 286 guests, and 6 robots.
Topics128,283
Posts1,058,521
Members48,490
I've got a 46 Chevy 1/2 ton truck that has a 87 Camaro rear end that is installed over the springs and springs have been re-arced to lower truck. I've got set of shock brackets that I'm going to use and will install lower bracket on top of springs. My question is how do I figure out what angle do I attach shocks to out side of the frame? Thanks
Crusing in the Passing Lane
You are on your own imagination with non-standard parts.
Ed
Lean then forward, adjust for proper limits, and you will be good to go. Allow more travel in compression then extension. I would say 2/3 compression, 1/3 extension. You can increase or decrease how the shocks control axle movement by the angle they are mounted. Straight up and down will provide the most control. The same thing if you lean them towards one another.
