3 members (HareCanvas, Steveoreno, stlcardinalsguy), 116 guests, and 4 robots.
Topics128,184
Posts1,057,266
Members48,467
Does anyone know which hose clamps were used on the 1959 Chevrolet six engines?
I have seen mostly screw type replacements. I was wondering if anyone has an original truck with
the factory supplied hoses or clamps?
thanks, 59 shortfleet
there is a picture in the factory assembly manual (section 6, sheet 19.00) that shows a crossed-wire clamp on both ends of the upper hose and the bottom of the lower hose. The top of the lower hose has a band clamp which is tightened with a bolt on the side.
Hello tom,
Thank you for the picture and the comment on the two styles of hose clamps.
I had not thought to look in the 55-59 assembly manual.
respectfully, Charles
Charles, good to see another Okie Bolter. See you in El Reno at Smalltown Weekend? shake
