| | | Forums66 Topics128,191 Posts1,057,362 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 127 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 127 | Can an SM420 be adapted to work on a 1946 with the 216 engine? | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | The bottom, right mounting bolt will have to be relocated; can drill a new hole in bellhousing or drill and tap matching hole in front of trans. Check retainer diameter, input shaft stick out, clutch spline, etc.
Ed
| | | | | Joined: Aug 2005 Posts: 278 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 278 | Bearing retainer diameter will be larger for SM420. You will need to either machine larger hole in 46 housing or use a 48 plus (through 52?) bell housing. If you use a 48 plus housing with a 1/2 ton 46, you will be faced with the issue of how to mount your clutch pedal. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | '46 bellhousing might also not allow 11" clutch, so if 10" clutch will work OK fine, otherwise use late bellhousing.
Ed
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I welded original clutch mounting ears off an early bellhousing on my late bellhousing. Others have used bolts to mount clutch arm.
Ed
