5 members (Ponchogl, Otto Skorzeny, Materman, dt235sd, walter74), 104 guests, and 1 robot.
Topics128,049
Posts1,055,634
#1248920 12/31/2017 4:49 PM
Finally got around to following Hot Rod Lincolns advice, and added a heavy duty headlight harness from LMC to my 55 2nd truck. Its a plug and play harness and comes with two 30 amp breakers. Now the power, for the headlights, comes directly from the battery and does not go thru the stock headlight switch and circuit breaker. Stock headlight switch still functions as original. I had added halogen headlights to my truck several years ago, and they would overheat the circuit breaker on the stock headlight switch sometimes. (Not good!) Harness was complete, ready to plug in and very nice quality, $30. I did have to cut 1inch holes thru inner fender panels to route harness to headlights. Thank you Hot Rod, you da man!
H Online: Content
Headlight relays are nothing new- - - -Dad's shop was installing them on 6 volt vehicles in the early 1950's, and other drivers would flash their lights at cars with the relays installed, thinking the driver had failed to dim his lights. Running voltage all over the place before it gets to the headlights just naturally drops a lot of light output due to circuit resistance. Glad it's working for you!
A lot of people here in Southern California don't have a clue what high or low beams mean. They just drive in whatever the lights are set. The cops don't seem to enforce this at all. We see the super bright blue/white headlights and all one can do is look to the right until they pass. Sign of the times, I guess..... But let me say, my old '55, now with the halogen lights and heavy duty harness, has some killer high beams when needed!
Crusing in the Passing Lane
Cops don't enforce that and other laws in Colorado, either.
Ed
I like to install a relay on brake lights as well. Some brake light switches don't operate with a snap action and the relay helps prevent frying the contacts of the switch. Especially true for the line pressure switches some systems use. It also takes load off the brake switch when pulling a trailer with lights.
