4 members (Deegs53, F100Ranger, JoergK., Hush), 152 guests, and 1 robot.
Topics128,192
Posts1,057,350
Members48,469
#1248635 12/29/2017 9:29 PM
Well,
We have the 235 running after a 18 month pause in the build... all looks good except one thing.... my water pump failed on my while running it... which caused me to notice another problem
my back water plug was not in and no water came out of the plug. (see pic hole #2) Water was streaming out of hole #1 so we put in a bolt to plug it... Head has water in it confirmed by pulling temperature sender plug.
My question is why would the back hole not have any water? What are my options to unclog? Block 55 235 and is a fresh rebuild bored and vatted...
Thanks in advance.
tim
53 3100 purchased brand new by my wife's grandfather... full frame up restore in progress.
When you did the rebore/rebuild did you carefully and completely clear/clean the rear of the block water passages?
That is a good question. My answer is yes but that was 2 years ago... does that mean a tear down is in order?
I had the same problem today. I pulled plug #2 to prepare for cold weather on a newly rebuilt 235 engine but nothing came out. I poked a screwdriver in the hole and pulled out black sludge. Still no water. I put a little compressed air in the hole until I heard it bubble up and it started flowing with a bunch of black crud. I guess the rebuilder did a crappy job cleaning block.
Originally Posted by DadandSon
Well,
Thanks in advance.
tim
This is a fairly common occurrence with trucks which were used for hard work on the farm. I suspect that the majority of the black crud is the accumulation of stop-leak added to the cooling system over the years of its life to keep a damaged radiator in service (they were relatively expensive back then).
I base this assumption on the fact that it is black and it solidly glued to the cast iron and nothing seems to dissolve it. The ones I have cleaned had a significant amount of it which could not have gotten in there via impurities in water added to the system.
BTW, the "#1 hole" in your block is not a coolant hole. It is a boss which was drilled for a bellcrank for the accelerator rods. It appears to have been drilled too deep and now leaks water. Your fix should take care of that.
Carl
Try using a metal coat hanger wire in hole #2 , it should break through the crud.
Tim
1951 3100 Chevrolet
I like to use a dull 1/4" drill bit,(or one that I've deliberately blunted the cutting edges on a grinding wheel) in a cordless drill to dig into the deposits at the bottom of the block with. Run the drill slowly and nibble away at the deposits until the coolant starts to drain. Just be careful not to drill a hole in a cylinder wall!
I too have the same problem - 235 '55 that wont drain. I have tried running the coat hanger but the drain passage seems to go in about 1" and then turn upwards. If this is correct, drilling can't help. I have tried a piece of stranded cable, but it also runs into interference. Is there some other suggestion other than to wait for an engine tear-down?
Bob
BobS46
The 1/4" pipe thread is the same as an air line fitting. Screw a male quick-connect fitting into the block and attach an air hose to it. 100-something PSI of air pressure should clear the clog - - - -just be sure to remove the radiator cap or take a hose off to protect the radiator core.
I too have had success with a variant of Jerry's advice. If you hard connect an air line and put it on a line with a valve on it from the compressor you can ease into it and get off when the plug clears. Clearly best to do this outside.
Allen
1974 Stingray Corvette
I just do it the redneck way- - - -pinch the hose off and ease the pressure into the block a little at a time.
Tried that - I heard air passing into the engine, but it did not clear.
Bob
BobS46
Keep the air flowing for a while- - - -the clog will free up eventually.
Another trick similar to one that Jerry mentioned earlier about using a dull drill bit is to cut about a six to eight inch piece off a wire coat hanger, then heat up the end with a torch and pound the end flat about 3/8" so that the end looks like a paddle. Put it in an electric drill with the paddle end facing out, then run it in and out of the drain hole. It works like a plumber's snake. The coat hanger wire is thick enough to hold the paddle shape on the end, but flexible enough to go up the water jacket.
On tough ones, I have found the combination of the dull drill bit, compressed air and the coat hanger snake to work.
If you are getting air to pass, you are getting close. The snake might help to loosen the last bit of crud that can't be reached by the dull drill bit.
Matt
Matt
That is a creative idea. I will make a similar water jacket snake at the next time needed.
Lots more pictures
Had this problem with the 265 in my '56 sedan, pulled all the freeze plugs I could get to and flushed with water hose and dug with coat hangers. This produced about a one pound coffee can of krap from the water jackets. Best of luck
1946 1/2-Ton Chevy
A piece cut off an old speedometer cable chucked into a cordless drill motor makes for an excellent "snake" for chasing crud in places like water jackets. Just be sure to melt the end of the cable into a solid blob with a torch to keep it from unraveling. I've also used a short piece of very heavy weed eater string as a snake for clearing pasageways like oil galleries in crankshafts, etc.
Ok, I believe I have this cleared up... I tried every method above so thank you so much for the help.
Your no.1 hole actually gets a round head screw with a rubber or neoprene washer.
I tried to post a photo but I will be darned if I can figure that out.
Do a google search for 235 Chevy block and then image and you should see what it looks like.
Mike
Good try, Mike
photo is attached, below
You are gonna have to tell me how to do that!
I take it there is no way to post a photo that you have on your device, say an iPhone or iPad, but only through a host, if anyone knows?
Mike
You have to have a file directory for storage and for a "viewer/finder" - iPad & iPhone do not have a directory viewer/finder (file manager).
Well that is a complete bummer.
Mike
I used a piece of 1/8" line with some turned up at the end. I put it in and rotated it. I did it a number of times and just as I was about to give up it started to drain. I have had a number of these sixes that never did drain out there and it made no difference in normal use.
1951 1 Ton Completed
