| | | Forums66 Topics128,096 Posts1,056,473 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2015 Posts: 94 'Bolter | | 'Bolter Joined: Oct 2015 Posts: 94 | hello . i have been searching for calipers with emergency brakes to swap the calipers i have on a Dana 70hd rear end . the rear end came out of a 1990 motor home and had a transmisson parking brake that was for an automatic transmission ,i have a manual 4 speed , every thing i have found comes close but not exact . i am sure they would make type of a caliper i just need to change out the calipers . i have checked at a brake supply in my area no luck . the calipers say bendix on them . please help me to stay stopped . 1pete1 | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I’m not aware of any caliper for that with parking brake option. Find and use a transmission with brake, or add brake to yours. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | If you have a 465 trans., there are trans. with integral park brake on EBay.
Ed
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Also, I’ve never seen parking brake cable anchor brackets to go with the brakes on the 10 lug Dana 70HD or 80. Which if non existent means that parking calipers also don’t exist for that setup... or if you found something you’d need to make the brackets. | | |
