2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
#1248848 12/31/2017 3:35 AM
Can an SM420 be adapted to work on a 1946 with the 216 engine?
jetmech6868 #1248879 12/31/2017 1:18 PM
Crusing in the Passing Lane
The bottom, right mounting bolt will have to be relocated; can drill a new hole in bellhousing or drill and tap matching hole in front of trans. Check retainer diameter, input shaft stick out, clutch spline, etc.
Ed
jetmech6868 #1248926 12/31/2017 5:01 PM
Bearing retainer diameter will be larger for SM420. You will need to either machine larger hole in 46 housing or use a 48 plus (through 52?) bell housing. If you use a 48 plus housing with a 1/2 ton 46, you will be faced with the issue of how to mount your clutch pedal.
jetmech6868 #1248985 01/01/2018 12:40 AM
'46 bellhousing might also not allow 11" clutch, so if 10" clutch will work OK fine, otherwise use late bellhousing.
Ed
jetmech6868 #1249171 01/02/2018 3:50 AM
I welded original clutch mounting ears off an early bellhousing on my late bellhousing. Others have used bolts to mount clutch arm.
Ed
