| | | Forums66 Topics128,037 Posts1,055,466 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Gents, Trying to find 2 parts and I have no clue what the name is. Engine is a 216
1. Engine block (water jacket) Drain plug. “T” handle looking plug on the drivers side of the truck that drains the antifreeze.
2. The shut off valve to stop antifreeze from going to the heater core.
If you guys know the names, I will go research them.
Thanks, Chris | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | #2 Heater Control Valve.ðŸ›
| | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | #1 is called a "drain petcock" It's got a left hand thread on the T shaped piece so it screws in and opens up a drain passage when the T is turned counterclockwise.
#2- - - -this can be either a simple screw fitting shutoff valve with a T shaped handle, or one controlled by a cable from inside the dash. The original-equipment cable valve is called a "Ranco" valve, and the best you can get is a good used one. New ones are unobtanium. Several simple aftermarket cable controlled flow restrictor valves are available at local parts stores or on ebay. Search "heater control valve". Jerry
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | I'll need to check the thread size on one of my engines in the morning, but if it's a 1/4" NPT, the radiator petcock will definitely work. Jerry
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Would it be dumb to just put the correct sized bolt in the hole instead of the PETCOCK? Would it make that much of a difference? It would make draining it a lot harder due to lack of controlling the stream. I want to do it the right way, but just asking questions in case of an emergency later down the road.
Chris | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | You won't find a correct sized bolt to fit a pipe thread due to the taper. | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | The right part is cheap and available at any parts store. Why make an easy fix complicated? Jerry
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I was just curious. I have every intention to do it right | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You won't find a correct sized bolt to fit a pipe thread due to the taper. Would this work - 1/4" NPT brass male plug?If not, what type/spec of taper? Chris, you can "control the stream" by inserting a small hose into the opening or over the nipple (depending on the style). | | | | | Joined: Feb 2004 Posts: 29,751 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,751 | 1/4" NPT is a standardized thread no matter what kind of fitting is used. The petcock has an extended outlet that a piece of 3/8" rubber fuel line fits perfectly if you want to direct the stream into a catch container, etc. Jerry
| | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | Ok, perfect, I guess that I will be going to get some parts today and get the thing up and running!
Chris | | | | | Joined: Jan 2013 Posts: 2,232 Moderator: Interiors, Texas Bolters, Name that Part | | Moderator: Interiors, Texas Bolters, Name that Part Joined: Jan 2013 Posts: 2,232 | I found the petcock but having a hard time finding the heater control valve. I am thinking about putting on a male portion into the threaded part and putting inline control valve farther down the line. Thoughts? I would really like to have heat this winter if I drive her on nice days.
Edit: Found part and ordered it!
Chris
