Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 61 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#1248418 12/27/2017 10:29 PM
Hello. I have a closed PCV system on my truck. I am never sure about which PCV valve to use on my 1956 235. I am currently using a Purolator PV679. The pintle inside of it has an "A" stamped on it. Do the letters have anything to do with the size of the spring tension or hole in the end of the PCV valve? Is the letter that's stamped on it indicative of the engine vacuum and engine size? I've also seen an "F" stamped on these too.
Does anyone know which one would be the best for my 235 that gets around 18" to 20" of idle vacuum when tuned? Should I also be concerned with the lettering on the inside of the PCV pintle?
Thank you. Mark
1956 Chevy 3200, 1/2 Ton, 235 CI
https://photos.app.goo.gl/TQQo1YnFjs3U7xB57
MarkT #1248468 12/28/2017 5:20 AM
Check out this PCV how to by Deve. He tested a few valves to get the right one for his system on a 235.
It's a small world, but I wouldn't want to paint it.
MarkT #1248499 12/28/2017 3:45 PM
Thanks.
