6 members (Otto Skorzeny, 55shaker, Uncles51, FrankenChevy, mk72, 1 invisible), 83 guests, and 2 robots.
Topics128,022
Posts1,055,387
Members48,422
#1248312 12/27/2017 1:38 AM
Working on a 47 Chevy loadmaster 2 ton. I’ve replaced the front 2 wheel cylinders and rebuilt the rear 2 as well as rebuilt the master cylinder. I’m scared to mess with the hydrovac. Should I pull the unit off and disassemble and clean/inspect? The cylinders have all been a mess. I’m guessing the hydrovac is going to be dirty too. Suggestions?
Big Bolt Forum Moderator
It is probably best to pull it apart. That being said, I did everything but that on my 58, (including all the steel and rubber lines) and mine has been just fine.
Mike
