| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2016 Posts: 70 'Bolter | | 'Bolter Joined: Nov 2016 Posts: 70 | Working on a 47 Chevy loadmaster 2 ton. I’ve replaced the front 2 wheel cylinders and rebuilt the rear 2 as well as rebuilt the master cylinder. I’m scared to mess with the hydrovac. Should I pull the unit off and disassemble and clean/inspect? The cylinders have all been a mess. I’m guessing the hydrovac is going to be dirty too. Suggestions? | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | It is probably best to pull it apart. That being said, I did everything but that on my 58, (including all the steel and rubber lines) and mine has been just fine. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | |
