| | | Forums66 Topics128,079 Posts1,056,286 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | Had to pull my head (there will be more questions). The bolts got mixed up. Can any one tell me where the long bolts go? I would suggest using the diagram on http://devestechnet.com/Home/HeadTorque web page as a reference. It is a 235 engine. Bob
BobS46
| | | | | Joined: Sep 2007 Posts: 393 'Bolter | | 'Bolter Joined: Sep 2007 Posts: 393 | 16, 14, 8, 4, 3, 7,13,18 are short (i.e. the ones outside of the valve cover)
It's a small world, but I wouldn't want to paint it.
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | The simple way to double check things is to stand the head up on edge and slide the bolts into the holes - - - -when they're in the right place, all of them should stick out the bottom of the casting the same distance so the thread engagement into the block will be the same for all the bolts. Jerry
| | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Jerry, when are you going to get around to writing "The Book According To Hotrod Lincoln"? I am thinking about an entire book of quick hitting, short winded tips for those of us with attention difficulties who fall asleep when the the subject matter gets too wordy. And whatever you do, don't forget to add your signature wit (including the kind of wit which some, all-to-often, take too seriously or personal)
Carl 2 or 3 brain cells short of understanding many things mechanical
