8 members (MickeyP, dt235sd, lumbersawyer, Otto Skorzeny, Joe H, 50Chevy3100, 3B, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,014 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | What is the best finish for wheels? I have the three piece split rims off a 1954 1 Ton. I would think they would get all scratched trying to put the split part on. Is there a really durable finish? Possibly something from POR?  | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | 55, any time you use mess with a split rim it is bound to get scratched. My personal preference for the best use of a split rim is either a dock anchor, flower planter or fire ring. But that is a personal preference.
If you are going to use them for the sake of authenticity, I would suggest you get the tires you are going to run with mounted first, then clean, mask and paint them. That way you don't have to worry that they will be scratched by the person you have mount your tires.
1949 "Heinz 57"
| | | | | Joined: Feb 2007 Posts: 7 New Guy | | New Guy Joined: Feb 2007 Posts: 7 | Powder coated wheels are the best. Although one should watch out for UV resistance... | | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | | | | | | Joined: Feb 2007 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 52 | Not to nit pick here or hyjack a thread but is powder coat autentic? I know the process is has not been around since way back but can anyone tell the process just by looking at it?
Kenny B. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I doubt many could tell the difference by lookin, between a good original style gloss paint job and powder coat .... even a car show judge Bill | | | | | Joined: Nov 2000 Posts: 700 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 700 | Interesting thing happened today with my wheels. My painter had the the tires dismounted across the street at a tire place. After priming them the intent was to remount the the tubes and tires, but not inflate them until finishing the base coat/clear coat process. After prepping the wheels they went back across the street and the tire guy informed them that they could not remount the tires because they were over 5 years old (Actually, they are about 20 years old but show very little signs of age.) They took them to another place and got the same story. Finally they were taken to xyz tire place and had the job done.
All of that being said... One day I will more than likely have them demounted again, the wheels blasted, and then powder coated. I will more than likely buy some new Cooper tires at $150 or so a pop at this time. Of course, the problem again will be remounting the tires without nicking the powder coat.
BTW, I've seen everything from fences, engine parts, patio furniture, my Harley sliders, etc. powder coated and you really can't tell it from "real" paint. My 1941 in the Stovebolt Gallery My Photo AlbumBut I tried, didn't I? ... At least I did that. RP McMurphy The past belongs to the future...but only the present can preserve it. Besides the noble art of getting things done, there is a nobler art of leaving things undone. | | | | | Joined: Nov 2004 Posts: 2,407 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,407 | If you powder coat them, can they be touched up? If not, I would suggest to just paint them. Then touch them up after the tires are mounted.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I just picked up my rims from the tire store this PM. Had them powder coated and a new set of Coopers. The only problem with powder coating is color choices. You are only able to choose the colors that are generated for power coating, pretty basic. I selected a color they call "hunter green" which looks somewhat like the origional on my truck. I will try to match that color when I paint the truck.
~Jim
| | | | | Joined: Jul 2006 Posts: 243 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 243 | big chevy.... what did you use on your frame? looks awsome... | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Thanks dbone. I had it sandblasted and primered and then a black epoxy.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | dbone: I see you are in Dripping Springs. I have a place in Blanco. My blasting is all done at Abernathy's Restoration. He has a great rod shop 7 miles out of Johnson City. He did the frame for me. And his prices are a whole lot better than here in Dallas. Their website is: http://www.abernathyrestoration.com/
~Jim
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Thanks for the input. I'm leaning towards just using regular paint. I have the stupid three piece split rims and will without doubt end up scratching them while putting them back together. | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Those three piece rims are why I made the boat anchor comment in my post above. Unless you are going for full authenticity, there are much safer alternatives for yourself and whoever mounts your tires.
If you are dead set on using them, (they aren't called "widowmakers" for nothing), make sure your tire guy uses a safety cage or retainer straps or chains while mounting or demounting the tires. If he doesn't, take them to someone that does.
1949 "Heinz 57"
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Thanks Dave O., I am trying to keep it pretty original. I just bought six 700x18's for "Big Orange" ($$$$ ouch) and will use the factory rims. I have experiece with the split style rims and will probably just do them myself. If you don't hear from me in the next couple weeks.....send an ambulance!! I do like the fire ring idea though. I have a bunch of 8.25 20's I think I'll do that with! | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | Powder coat will flake after a couple of years,has something to do with expansion from hot and cold I think. Could just be my problem. Going back to paint next time though. | | |
