4 members (Otto Skorzeny, Tiny, 2 invisible), 100 guests, and 4 robots.
Topics128,142
Posts1,056,478
Members48,441
Hi all, first off, merry Christmas!
Second, in my absolute wisdom I misplaced the snap ring that was in my countershaft, the one that holds the big ball bearing in place. Now I have a few snap rings in my rebuild kit that seem to fit.
Can anyone help me identify exactly which snap ring holds that countershaft ball bearing in place?
Would be the best Christmas present!
I LOVE MY TRUCK
1959 Chevrolet Apache 38 Panel Truck in the Gallery
' Offline
The SM 420 4 speed trans . 1955 to 1966
uses the SECOND DESIGN counter shaft .
http://i669.photobucket.com/albums/...ond%20design_GM_3813197__zps6izwqfgb.jpg
The second design is mounted with ONE bolt at the rear.
The groove on the counter shaft uses a snap ring / circlip which holds the rear
bearing in place .
I'm assuming this is the snap ring you need ?
This snap ring I have in mind MEASURES ( .050 " ) thick .
You should carefully measure the WIDTH of the groove on your counter shaft .
If the groove measures right around ( .050 " ) width .
I would be 99% certain that the GM part you would need is......
GM # 4.422 - GM # 591959
Availability of GM # 591959
Friesen Chevrolet
Sutton, Nebraska
phone: 402 -773 - 5538
Friesen has ( 14 ) GM # 591959 in stock
Dan's GM Obsolete
Chinook, Montana
phone: 406 - 357 - 2615
Dan's has ( 14 ) GM # 591959 in stock
Howe Motors
Claremont, N.H.
phone: 603 - 542 - 5181
Howe Motors has ( 4 ) GM # 591959 in stock
see PIC below
not a great PIC........but better then no pic
http://i669.photobucket.com/albums/...Ring_SM_420_1955_and_up__zpsporgsmuu.jpg
You will also need a new front of the case counter shaft Cover / Spacer
http://i669.photobucket.com/albums/...M%20420%20COVER%20SPACER_zpsldrcszue.jpg
Dan's Obsolete has ( 10 ) GM # 3795505 in stock
George
'54 3600
1954 3600
Now cruising in
The Passing Lane
