The SM 420 4 speed trans .
1955 to
1966uses the
SECOND DESIGN counter shaft .
http://i669.photobucket.com/albums/...ond%20design_GM_3813197__zps6izwqfgb.jpgThe second design is mounted with
ONE bolt at the rear.
The groove on the counter shaft uses a snap ring / circlip which holds the rear
bearing in place .
I'm assuming this is the snap ring you need ?
This snap ring I have in mind
MEASURES ( .050 " ) thick .
You should carefully measure the
WIDTH of the groove on your counter shaft .
If the groove measures right around ( .050 " ) width .
I would be 99% certain that the GM part you would need is......
GM # 4.422 - GM # 591959Availability of GM # 591959
Friesen Chevrolet
Sutton, Nebraska
phone: 402 -773 - 5538
Friesen has ( 14 ) GM # 591959 in stock
Dan's GM Obsolete
Chinook, Montana
phone: 406 - 357 - 2615
Dan's has ( 14 ) GM # 591959 in stock
Howe Motors
Claremont, N.H.
phone: 603 - 542 - 5181
Howe Motors has ( 4 ) GM # 591959 in stock
see PIC below
not a great PIC........but better then no pic
http://i669.photobucket.com/albums/...Ring_SM_420_1955_and_up__zpsporgsmuu.jpgYou will also need a new front of the case counter shaft
Cover / Spacerhttp://i669.photobucket.com/albums/...M%20420%20COVER%20SPACER_zpsldrcszue.jpgDan's Obsolete has ( 10 ) GM # 3795505 in stock
George
'54 3600
