6 members (dt235sd, Otto Skorzeny, carbking, klhansen, FAST55, Peggy M), 66 guests, and 3 robots.
Topics128,052
Posts1,055,719
#1247822 12/22/2017 7:25 PM
Keep seeing people talk about having 8 bolt or 10 bolt axels.Whats the difference with them?
Stooby #1247834 12/22/2017 9:23 PM
Big Bolt Forum Moderator
a 10-bolt or 12-bolt rear end normally refer to the # of bolts on the ring gear. (corporate 10-bolt, 12-bolt, or 14-bolt rear end.)
It can also refer to the # of lug nuts. 8 bolt is normally a 3/4 ton. 10 bolt would be the 1 1/2 or 2-ton. (I believe 1956, Chevrolet went to the 6-bolt "BUDD" pattern on the 2-ton axles.
Mike
69Cuda #1247889 12/23/2017 12:36 PM
Does the number of bolts make any difference to what ratio is in the rear.
Stooby #1247892 12/23/2017 1:50 PM
Stooby #1247899 12/23/2017 3:10 PM
On a "8 bolt" axle reference. They are not talking about axles from our Trucks. For instance my truck has an 8 bolt cover(and 8 lugs) but it's
referred to as the name of the axle a Eaton Axle.
To Help you Better. I'd be nice to know which truck you're working on.
Julian Carter
1970 Triumph GT6
1967 Triumph TR4A
1952 Chevy 3600
1948 MG-TC
Stooby #1247920 12/23/2017 6:27 PM
no, usually there are multiple ratios for each type of axle except on some of the bigger ones, especially the 2-speed like on my t-ton, there was not a lot of options (if any).
Mike
