1 members (1 invisible),
78
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Will a 48 3 speed trans 4 bolt side cover, shift forks, and shift arms interchange with one on a 55.2 3 speed trans?
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The side cover is the same except for the 1-R shift fork. The slider gear is wider on the later trans hence the fork is wider. There are two types of side covers: The ball type and the scissor type. Internal parts don't interchange but if both of the ones you have are the same, you can switch the parts. The 55-2 V-8 side cover is different than the 6 cylinder. The early truck side cover shafts are clocked with the 2-3 shift lever pointing up and the 1-R shift lever down. On V-8 trucks and 56 up 6 cyl both levers are down. Fred
| | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Fred thank you for the reply. What I really have is a 56 overdrive trans, and a 48 standard 3 speed, and I wanted to use the 48 side cover on the 56 trans. Cause my 55.2 truck has the shift linkage with the bell crank set up. Looks like I still have to take them a part to see if it's going to work.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | Brian, The 2-3 shift fork is a common wear part, use the best parts from what you have. Fred
