2 members (Hush, delky),
141
0
Mod | | | Forums66 Topics128,126 Posts1,056,354 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2017 Posts: 5 New Guy | | New Guy Joined: Dec 2017 Posts: 5 | I am starting to go through my 60 4x4 short fleet it is all original except the engine and bell housing. About 10 years ago I pulled out the 327 my uncle put in it in 1972,I replaced it with a sb400 that I had built and waiting to go in something. Now I am going to put her back to some what original. I have enough 235 and 261 parts to build either motor. Which would be the best, coolest? The truck came with a 235 if that makes any difference.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | "Best" or "Coolest" is a personal matter.
The 261 is a stronger engine.
If the year of either engine matches the year of your truck, you might want to use that engine.
Maybe someone knows if the 261 was standard in 1961 on 4X4 engines? | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Around here the 261 upgrade is envied for the ad trucks. Not heard of the engine in many Apache era trucks. Either way seems fair to me. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | It looks like the 261 was the standard engine on 1960 2WD C60 trucks (CLST60 or C60 LST)? What is the model number (if any) for a 1960 C60 4 wheel drive truck? And, what drive-train components were standard on a 1960 CLST60?
In 1960, the K10 and K20 (4WD) trucks were 4-wheel drive (4-speed manual transmission, and standard Thriftmaster 235, or RPO V8 327)
| | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | The 261 is 10.8% larger than the 235, far greater increase than the Cadillac stroker.
| | | | | Joined: Dec 2017 Posts: 5 New Guy | | New Guy Joined: Dec 2017 Posts: 5 | As of today, not yet leaning to either motor. .I am pulling parts, twisting micrometers and over thinking my belly button right now. The 261 is a complete and running motor ,oil pump, oil bath, oil filter,and all the goodies. Maybe tomorow | | |
