0 members (),
102
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Hey all! I have a hot street built 292 inline 6. Im looking into adding TBI in place of the 4 bbl carb. My 292 (bored to a 298) has over 300 HP and over 400 ftlbs of torque. Im running a 600 CFM edelbrock. I have a painless harness and a complete TBI from a 1993 Suburban with a 350 v8 with computer. My question is what CFM does the 350 TBI have? and what CFM does the 454 TBI have? and will any of these provide enough fuel to power the HP im putting out? Motor is in a 1954 Chevy 5 window pickup.
THANKS AND MERRY CHRISTMAS ! PS my motor mods Chevrolet High Torque 292 300+ HP 400+ Torque Block: 1974 Chevy 292 Crank- Polished Cam- Clifford 264 Hot Street Bored .040 (298 CI) High Compression Forged Racing Pistons Zero Decked 65K HEI Distributor Chrome Moly Push Rods Head: 1966 Chevy 250 Machined .030 Oversized Stainless Steel Valves 1.94/1.60 Bolt Bosses Removed Premium Hi-Flo Lump Port Kit Big Block Roller Rockers Port and Polished Offenhouser 4bbl Intake Edelbrock 600 CFM Carb Pace Setter Full Length Tube Headers 12" Heavy Duty Clutch
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | TBI was/is a poor substitute for real port injection that the manufacturers used as a stopgap measure while they developed SEFI systems. Your carburetor probably does a better job than any TBI system would. If you're going to go to the effort of installing fuel injection, why not adapt a sequential port injection system off a newer engine like the Atlas DOHC six? Jerry
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Jerry, where would the best place to put the injectors be, a big one in each Siamese intake port to take care of two cylinders or?
Ed
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | TBI for what it did was dependable. And a lot easier then trying to convert a straight 6 to a port injection engine.
CFM has nothing to do with the carburetor being used or TBI system.
CFM is the maximum amount of air that an engine can take in and pump out. It is based on the total displacement of the engine. A 350 SB would have about a 600 - 650 CFM. Though engines do not move the full amount of air that they can. Average volumetric efficiency, the real amount of air that an engine can flow through it is about 80% of what the mathematical determined amount is.
So that 600 CFM becomes 480 CFM.
So would go with the 350 TBI system because it's CFM will be much closer to your 292 then using the TBI system from the 454 engine.
The 454 system would be calibrated to flow more fuel then the 292 would need. Wasting fuel does not yield more power.
Also you are going to use a TBI system don't forget you will have to change the engine pipe because you will need a oxygen sensor. Jeffrey | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | A single injector in each port would work, just program the computer to fire it twice in each 4 stroke cycle. Since the inline six firing order alternates between front and rear cylinders, each injector shot would need to supply enough mixture for only one cylinder. That's also why 3 carburetors work better than two. Each carb of a 3-carb setup only needs to have the volumetric capacity to supply one cylinder. If the 292 has already had the lump port modification, aiming one injector dead center of each port would be an ideal situation. Jerry
| | | | | Joined: Feb 2012 Posts: 96 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 96 | port injection with siamese intake is hard to get to work right usually end up with one rich and one lean cylinder one steals part of the other's charge
O2 sensor isn't hard to add just weld a threaded bung and drill a hole
| | | | | Joined: Feb 2012 Posts: 506 'Bolter | | 'Bolter Joined: Feb 2012 Posts: 506 | Beast;
Do you have dyno runs to verify your HP and torque numbers? If so, what modifications did you do to the engine to get there?
Larry
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | one rich and one lean cylinder one steals part of the other's charge. Look at the firing order on an inline six. It's hard to steal a charge when one of the intake valves sharing the port is closed for 360 degrees of crankshaft rotation. Jerry
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Im just looking to do a simple fuel injection. i dont want to get too crazy. I have all the stuff for a 350 TBI. Here is what I did to my 292: Chevrolet High Torque 292 300+ HP 400+ Torque Block: 1974 Chevy 292 Crank- Polished Cam- Clifford 264 Hot Street Bored .040 (298 CI) High Compression Forged Racing Pistons Zero Decked 65K HEI Distributor Chrome Moly Push Rods Head: 1966 Chevy 250 Machined .030 Oversized Stainless Steel Valves 1.94/1.60 Bolt Bosses Removed Premium Hi-Flo Lump Port Kit Big Block Roller Rockers Port and Polished Offenhouser 4bbl Intake Edelbrock 600 CFM Carb Pace Setter Full Length Tube Headers
I got my numbers from what the stock 292 put out and added the HP of each upgrade. I got all my performance parts and HP/Torque numbers from the famous inline 6 builder Tom Lowe.
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Jeffery, would the 350 TBI handle 300+ HP?
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | How about sharing some dyno run numbers with us? It would be helpful to know where the torque curve is now, and whether or not there are any RPM ranges where the torque needs to improve. A 264 duration cam probably doesn't need much over 9.5:1 compression. What's your static compression ratio? Jerry
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | i dont actually have any dyno numbers. my compression is 9.5 | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Without dyno info everything is just a guess. Rear wheel info is way more usable than flywheel readings as everything parasitic is in place during the pull. Crude injection, while reliable, will never give the power readings of a good carb set up. Corvettes with the Rochester injection always got their butts whipped by the carbed ones. We have built a few hot I6's but NEVER one without a 12 port head. Before the Atlas we put a 240/300 Ford and even one Slant 6 Chrysler in Chevy trucks. After just 70 years GM finally gave performance inline guys something to work with. Now if Jerry would just his idea engine purring on the dyno we have a couple of candidates waiting. Old age, weak muscles, and bad eyes must now wait on the young(er), strong, and smart.
Evan
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | So your saying that the carb will be better than the TBI? | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | MUCH better! I was in a GM Training Center class in 1963, shortly after they discontinued the mechanical fuel injection system on the 283 and early 327's in the Corvette. Being young and wise, I took it upon myself to chastise the GM engineer who was teaching the class over that decision. He commenced to educate me in front of the whole class:
1. "The Rochester 4 barrel makes more horsepower and torque than the fuel injection engine everywhere EXCEPT wide open throttle." 2. "GM loses money on every injection system we make- - - -customers would refuse to pay a break-even price if we charged that much." 3. "If every gasoline engine in the world was equipped with the best fuel injection system we know how to build, and someone came up with carburetion in its present stage of development, it would be hailed as a MAJOR advance in fuel system technology!"
I kept my big mouth shut for the rest of the class, and actually learned a thing or two. When Volkswagen brought out a rudimentary electronic injection system in 1966, things improved some- - - -until the truckers learned that a CB radio with a power booster could turn the injectors off when a VW was passing them! Jerry
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | very interesting! Cool thanks for sharing! | | | | | Joined: Dec 2008 Posts: 1,922 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 1,922 | EFI advantages: 1. the FI manifold can includes shapes and volumes that will not suspend fuel droplets and would cause fuel distribution issues with a carburetor. Sometimes this is worth some power, but it depends on the manifold design. Example: Ford 5.0, where the air from the TB reverses direction in the plenum. 2. the FI throttle disc(s) area can be greater than a carburetor because engine vacuum does not actually pull fuel from the bowl, and will work below .25 Hg". This gives a slight improvement in pumping loss - but only if you use a system larger than your carburetor. 4 bbl. carburetors are normally calibrated for engines that can pull 1.5 Hg" at WOT. Carburetors rated by CFM are fictional: "600CFM" means it will flow 600 CFM at 1.5 Hg" on an engine that flows 600 CFM. If the engine is bigger, it will flow more than 600 because it will pull higher than 1.5 vacuum. If the engine is smaller, vacuum will drop and the carb will flow less than 600. For a V8* the usual calculation for CFM, where: D = displacement in inches RPM = engine speed at peak power VE = efficiency, less than 100% in anything but a race engine CFM = D X RPM X VE / 3,456 Example: 298", 5,500 RPM, 95% (excellent) VE CFM = 298 X 5,500 X .95 / 3,456 = 451 Conclusion: 600 is already too big
* the intake characteristics of engines with less than 7 cylinders are quite different than a V8. The CFM capacity for a 6 cylinder has been estimated at 10% higher than a V8, 4 or less cylinders even higher.
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | Interesting. I think i get some of that. I have noticed that my truck does smell of gas fumes alot. Espesially through the tail pipe. I put the 600 CFM carb on the 298 because thats what Tom Lowe (the inline 6 builder) told me to use. Maybe im not burning all the fuel thats going in... | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | An oversized carburetor runs lean, not rich, because the velocity of air through the too-big venturis doesn't generate enough vacuum to pull the fuel from the float chamber into the airstream. It's possible that low intake manifold vacuum might be causing the power valve to stay open most of the time, causing a too-rich mixture. It might also be prone to bog down on quick acceleration or have a flat spot just off idle because of an improper transition from idle to part throttle. Jerry
| | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | I havent had any bogging or flat spots. just strong gas smell at the tail pipe. You think i should downsize the carb?
| | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | What do the spark plugs look like? If it's running rich, they will be black and sooty. Proper mixture and good ignition makes plugs have a tan to chocolate brown color with no noticeable deposits. Long duration cams have a tendency to run rich and/or waste a lot of gas at idle, so unless something other than the exhaust smell indicates you've got problems you could probably get by "as is".
Like Evan has said, doing some dyno runs is going to be the only effective way to make a high performance engine work anywhere near right. Before an assistant principal at the school where I taught discarded a file cabinet full of records by mistake, I had a couple of hundred hours' worth of documentation of dyno runs on small block Chevy round track racing engines my students had built for the 5/8 mile NASCAR short track at Nashville Tennessee. Two local car owners supplied the funding, and my students built and tuned the engines. The kids who were at least 16 years old got to be on the pit crews during the summer racing season. Jerry
| | | | | Joined: Feb 2000 Posts: 5,197 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,197 | I suggest you invest in an Air Fuel ratio gauge with O2 sensor in the exhaust pipe. You will find out in about 2 miles of driving how the carburetor is functioning. I bought a stand-alone gauge from Speedhut, https://www.speedhut.com/gauge/GL258-AFWB-09/7/Standalone-Air-Fuel-Wideband-O2-gauge-8-5-18 , it was the best money I ever spent on getting an engine to run correctly. Its easy to customize the gauge to match your in dash gauges and hooking it up was super easy. Joe | | | | | Joined: Sep 2004 Posts: 201 'Bolter | | 'Bolter Joined: Sep 2004 Posts: 201 | cool this is great stuff! I will look into all that! Thanks so so much! | | |
