| Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Yes, look for water drain fittings as said above, pipe thread plugs at base of jugs, either side, remove them, then stick a strong wire in there to make sure water flowing through there that has accumulated over the years.
Ed
