7 members (baldeagle, Hotrod Lincoln, Bill Hanlon, fonz8261, greenie-reddy, 2 invisible), 367 guests, and 4 robots.
Topics128,162
Posts1,057,068
Members48,463
Fox
Offline
I have my chrome pieces back from the chrome shop and wanted to ask opinions on installation of the hood pieces. Should a gasket be placed underneath the model (9430- 1 ton) and GMC hood side call out? Any side piece I've removed didn't seem to have a gasket.
Also, I haven't seen a reproduction gasket for the GMC front chrome piece that attaches to the grill surround. Should I make one or install without a gasket?
Thanks for the input.
1970 Chevrolet C10
1950 Chevrolet 1-Ton Dually
"Ole Red Girl"
More pictures here
Parts trucks-
I rarely see gaskets on side pieces of older original classic cars, but on restored cars I see them often. How good is your paint, and how worried are you about the badges wearing on it?
1961 ford f500
1953 3100 five window (https://www.facebook.com/1953-Chevrolet-5-window-1533405913413610/)
1955-2 3200 big window (https://www.facebook.com/Leep3200/)
55yrs as a mechanic and retired. (kind of)
What LeeP said.
Gaskets would tend to trap debris and moisture too.
~~ Darcy
1959 GMC 9310 Canadian- built Shortbox Fleetside Deluxe
FootStomper
In the Project Journals Forum
They never had gaskets from the factory.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Hi Fox
I do not have gaskets on my trucks or the parts fenders. On yours or anyone with many hours in the paint
one does not want the pot metal to chip the paint and ultimately cause rust.
Just to be fussy gently dress the underside contact area with a fine file to remove any possible casting slag that could cause a high point.
And then snug down the speed nuts just enough. Put some dum dum under the nuts it will seal the holes for moisture and stop
the nuts from vibrating loose.
When your son is forty he will thank you.
Keep up the good work.
Howie
1 1955 Chev one ton. 261 engine
3 1962 Chev c-10 261 engine
4 1966 Plymouth VIP 5.7 GenIII Hemi
5 1966 Imperial Crown Coupe 440 engine
Fox
Offline
Howie,
What exactly is dum dum? I feel dum dum here! Haha! Is it a sealant?
My Toyota's rear bearings have piled up and the 1 ton is on the back burner now. 😁
1970 Chevrolet C10
"Ole Red Girl"
More pictures here
Parts trucks-
Plumbers putty. It was used by GM between the hood hinges and the cab to keep rain out of the cab.
Personally, I would worry about filing on a chromed piece of pot metal. I am concerned about opening up pot metal to the atmosphere, leading to corrosion as pot metal is prone to do.
