0 members (), 81 guests, and 2 robots.
Topics128,157
Posts1,056,876
Members48,458
#1246930 12/14/2017 11:29 PM
Y
Y Offline
Just wanted to find out if the rear axle on a torque tube was located below or above the rear springs? I've tracked an issue with the steering to the castor change caused by the open driveline/rearend swap? Thanks,
My axle is above. 1953 3100 torque tube, stock.
Joe
Y
Y Offline
I kind of thought that was how it was set up, but couldn't remember. I've seen pics with the axle under the spring, but maybe it was a 3/4 ton? I'll keep working on the castor issue. Thanks again.
3/4 ton has rear axle under the springs. 3/4 ton also has front caster shims that have a larger angle than the 3100 shims (if you're looking for more caster).
~ Dave
